Chally Posted June 24, 2011 Report Posted June 24, 2011 Which design will be better? #1 #2 or are they both wrong? Thanks in advance for any help. edit: Finally got the resizing issue solved.
alehound Posted June 26, 2011 Report Posted June 26, 2011 how many subs? Patiently waiting until 2016...the year in which I likely get to 300 posts... In which then, and only then, will I finally be able to get me some more decaf...
SkylarDunn Posted June 27, 2011 Report Posted June 27, 2011 .5ft^3 per sub, tuned to 26hz, with 8.5 in^2 of port per each .5ft^3 chamber. for multiple subs, do multiple chambers. should have flat responce down to about 31hz, with an f3 of about 26hz. Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
Chally Posted June 28, 2011 Author Report Posted June 28, 2011 Thanks for the help! Its 4 woofers and ended up doing a t port tuned to about 34hz didn't know they could go down to 26hz
