BMW 325i....back at it again.
I was driving to the store and bass just turned off. When i opened the trunk, amplifier was unmounted and it slide it to the side. The fuse on power wire was blown, so when i got home i changed it and mounted amp back where it was. Turned the music on and it was still not working, yet the green light was on. When i checked it again i saw smoke coming out of it.
i dont understand what you mean by the amp slid to the side. could you take a pic? are the subs still good?
since it was on top of the box it just moved little bit. Subs are fine. Don't have any pics, cause i took everything out.
amp was on top of the box and it stayed there. Sub terminals are on the side, so there is no way anything can touch them.
Have you measured the resistance on each side of the terminal?
still reads 1 ohm
tomorrow i'll take box out and check each coil on subs
you needed a better amp anyway. think of it as a blessing in disguise. and next time mount the amp better
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
What did you use to paint the box? I've been looking for that exact look.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
behr black paint
Premium, ultra? Model Number?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
