i'm going to be building a steel framed wall in the lumina sometime in the near future and was wondering how all you who have done so attached the wood to the steel frame?? just normal self tapping screws or what
i will be using angle iron for the frame welded to the vehicle and then single layer of wood on inside to help keep weight down and maximize space
or would pl400 glued to wood and frame be ok with couple bolts through the wood into the steel??
R.I.P!
(Nov-29-2009)
92 explorer
current build
the self tappers would work but also I would worry about them pulling but epoxy with the screws would work what is goin into this beastly wall :good:
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
i figured if i could drill holes and then weld some nuts to bottom of angle iron and use bolts to secure it with some sort of epoxy and i'll be using 4 apxx 15s and 2 cresendo 5500ds roughly 12k power on tap for now and then later on i would like 4 55000ds one per sub
next to apx 18 that is in the car right now
I beleive there is a way you can laminate te steel to the wood.
yeah thats what i'm wondering what type of glue/epoxy i would need to use to get it to be secure
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
the nuts welded on would work and the suggestion of somehow laminating the wood to metal has potential seeing all those apxx's is te sex!!! :good:
big 3 1/0
yeah im thinking of using some sort of loctite pl adhesive such as pl 375
and yeah i love my apx and apxxs
so far i have 2 apx 12s 5 apxx 15s and 1 apx 18 and i love them all
all i need now is a pair of 10s and i'll be set haha
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
they are makin an 8 now 1000 watts rms
big 3 1/0
weird my magnets are roughly 10" round so i donno how they plan on making an apx/xx 8 unless its new neo they were talking about
and if you dont mind can you answer my question in your 300 log
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Hmm... If you did 2 layers of wood, you could drill though the steel and wood, then put tee nuts in the wood and bolt the outer wood layer to the steel frame, then do an inner layer to cover up all of the bolt ends that would be sticking into the box.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
i was thinking something similar to that minus the t nuts just normal allthread/ bolts
bolt from outside frame into car going into wood with a recessed nut/washer then weld the nut to keep it there for good and then putting second layer ontop of that of .5" to cover up nuts
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
