amps getting hot help
mattp
are you sure you wired the subs up right??
i know with my buddys old xplode i wired it down to .35 and it didnt go into protect or anything instead it just burnt my finger when i went to touch it
R.I.P!
(Nov-29-2009)
92 explorer
current build
to start it's summer, so what ever ambient temp it is in yer car, the heatsink of the amp is already. next, the mids/highs amp is class A/B which runs warm to hot due to it's nature in circuit design.
unless your amp/amps are shutting down from thermal protect, i wouldn't worry too much
bad ground/clipping/low ohm load
go to frame or do front to back ground
in my saturn my front to back ground had less resistance than a strut tower ground
I was told that chassis ground was better them frame is not true. if I go front to back I still need another ground to the chassis of frame dont I?
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Mids/Highs Amp-MB QUART ONX4.125
Mids/Highs- Undecided
Sub Amp-DC Audio 7.5
Subs-4x DC Audio xl 18s
Alt- 270sp & 250sp Dc Power
Big 3 1/0
http://dcaudio.us/
SPL-LAB sells rep. for IOWA
http://spllabusa.proboards.com/
pretty sure it is I used the 12volt.com
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
when they start gettig hot I true sh!t off, dont want to f**k something up know.
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
dont have to. thats what the thermal circuit protects it from. so if it isnt, you're just wasting your time
Chassis/frame would be the same. You're essentially grounding to the body, run them on down to the frame.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 1586 Guests (See full list)
