badass build man! but we need videos please!!!
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Looks good, any vids?
As soon as I get two more batts in it I'll get some vids posted. I've tried a couple of times, but I can only get about 5 to 10 seconds of video before my breakers start tripping. I've still got a little more work to do on it also. I need to trim out the sides of the box and change the Fi logos on the dustcaps.
subs should beast. not a fan of aero ports but looks good man
4 I.A. Warden 15s
8 I.A. 20.1s
2010 140.0-149.9 Bass Race Points Champ/Over all champ
2010 140.0-149.9 Bass Race S.C. Regional Champ
2010 FL Regional Middle Weight Champ
2010 INAC Middle Weight Bass Boxing Champ
Once I get a couple more batteries in I'll work on some videos. Right now I can only take the volume up to about 85% before I start tripping breakers.
Will you plz put some ANL fuses in there and put them BREAKERS in the trash,
what he said
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
Get rid of the breakers already. And if you can run 2 pos 2 neg off each alt to the back. Looks nice let's get some numbers
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
