06 Civic Build - New Build List on page 60
Thanks guys! My biggest concern is frying that sub. I honestly don't think I can afford to kill it at this point. I'll keep working at it though.
On a different note, I decided after a long day of my daughters birthday party with a bunch of screaming 5 - 8 year olds, and then having to go out to my mother in laws to drop some stuff off for the finish of that job I've been working on, I needed some much needed Scooter Time! So I started the tablet build! This is going to do a couple of things. First it's going to switch my brain off the enclosure and refresh things a bit, and second it's going to actually get some portion of this build going.
So I picked up some tape tonight, and got out some stuff and the tablet and got to work protecting it.
Took the cover off of it. It does have the screen protector on it, but it obviously needs more before putting anything else on it, i.e. tape, resin, etc.
Front
Back
Not much to describe, other than I put a few layers on.
First layer: Glad Press and Seal. This should protect it from the tape any marks.
When all is said and done, the inside of the glass pan will have suede inside of it. This will do a couple of things. It'll help the tablet slide in and out easier, as well as, and more importantly, help to prevent scratches and marks on the tablet from sliding it in and out. So given that I need to account for the thickness of the suede, I decided to get out some scrap suede that I have, and just incorporate it into the protection layers so that in the end, the glass has been done with that thickness accounted for.
Did one for the front and back.
Then I started taping them on.
Next I got out the foil and wrapped a layer of it on.
And taped it up.
Now, it's time to glass!
Put down some parchment paper so I wouldn't have to fight getting it off the wood.
Cut a couple sheets of chop so that they were about an inch bigger than the tablet itself.
Then, I put the first layer on.
That's as far as I got tonight. It's pretty cold outside, so I'll leave it overnight and let it do it's thing. Tomorrow I'll get the second layer on and let it sit all day.
That's about it for now. More hopefully tomorrow night!
Ya I was nervous as hell. I was like "if this leaks through I've basically wasted $600.00"! But after the first brush mark went on I was like F&ck it, I'm in it to win it now! We'll know tomorrow if I've messed up or not!
For now, I have a head ache and I'm off to bed! Goodnight all! :drinks:
Got some more work done this morning!
Pulled the tablet and uncovered it for now.
After further inspection I discovered some voids on the edges. Those needed to be filled. I wanted a solid edge. That way when I trim it out, I don't have any voids that need to be filled later.
So I made a little wall or dam of tape to fill the edges in.
Filled
Much better edges. Not 100% straight, but it'll get covered up with the face plate.
Tablet uncovered next to the pan. Still works, whew!
Time to get a couple more layers on, it's pretty flimsy with one. Couple layers of cloth should do the trick!
Layer #2 total, Layer #1 of Cloth.
Layer #3 total, Layer #2 of Cloth.
One little issue point, but it'll get cut off in the end cause it's on the outside. But here you can see the two layers of cloth.
So that's pretty much it for the back of the pan. I think after this it should be plenty strong enough. Next step is going to be positioning it on the dash piece, and then getting it cut out. Then getting it into the actual dash and making sure it fits or making adjustments so I can get the face panel done and start the molding process.
Stay tuned, MORE to come!
Lookin sexy scooter! Good To see u back at it
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Thanks. Not sure how long I'll be able to stay with it, busy week, but I'll get more done soon.
Couple of pics with the tablet in it. It is a little big, however, with the suede and some a little work, it'll be fine.
Suede in
Tablet in.
That's probably going to be about it for the weekend. I'm gonna go out and hang lights with my daughters now.
More to come soon! Stay tuned!
Just spent at least an hour and a half reading this build log.
Absolutely fantastic. Your attention to detail is incredible!
I sent links to a few people to check this build out.
This thing is freaking awesome.
Mobile Electronics Certified Professional (MECP) Certified - Best Buy Autotech Certified
