ok so i finally have the system in and well ive been pounding it constantly for the last couple of days and today it didnt sound right. so i take the cover off the amp and i seen smoke (steam) comming from the ground. well heres the thing i have two amps T3002 and T5002 and the t 5002s ground was the only one doing this do you think if i upgrade the wires will it help? i currently have 0 gauge for ground to a d block which splits it to 2 4 guages one to each amp and i have the same for the power wire.
Jeffrey Ribeiro
Co-Founder
Gold Leaf Consultants
E: [email protected]
www.GoldLeafConsultants.com
CA refs: abdulwq, jordyo,sgdenny,shinju, bannok
SMD refs: Assman, zfrerichs, shinju, Loganberry
CCA refs: jordyo, SR SQ, nothing13, Mat-Romain, JohnnyRock1588, Brandon, KingRukus, SPDDMON, BlitzSix
CA feedback thread
http://www.caraudio.com/forum/showthread.p...384#post5068384
anyone???
Jeffrey Ribeiro
Co-Founder
CA feedback thread
could be a defect in the amp bro.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i have complete stock wireing i still have to do the big 3 but ill do it when i change the wires when i change it if it does happen ill send the amp back or maybe upgrade
Jeffrey Ribeiro
Co-Founder
CA feedback thread
Guest Nismofreak
um the amp or the wiring you did...got a pic of it? check your fuses
fuses wont have anything to do with it. if anything, you have a bad solder in the amp, or somehow the amp is defective.
