splfanatic Posted June 30, 2011 Report Posted June 30, 2011 Hi there guys, I am running a walled setup of 2 x Type R 15s , powered by Sound Magus X3500d , running at 0.5ohm Havent abused the Rs, gain is finely set , signal is totally clean Now the problem One of the Type Rs, which had its coil replaced with a genuine one, is rattling at low volumes. the rattle goes away if i slightly tap towards the right side of the surround and cone joint or even the cone only wat do u think is it, i got the surround unglued and realligned, the rattle went away but after a couple of hard hitting songs it was back :/, i gave it proper time to dry up though is the coil blown? is the spider - cone joint loose? or is it some thing else :? Regards
ALPINE408 Posted June 30, 2011 Report Posted June 30, 2011 sounds like the coils is not in the gap right did you shim it when you re coned? Have you ever had your woofers blown?
splfanatic Posted June 30, 2011 Author Report Posted June 30, 2011 sounds like the coils is not in the gap right did you shim it when you re coned? got it reconed from somebody else , but i dont think its shimmed any DIY to correct it ?
ALPINE408 Posted June 30, 2011 Report Posted June 30, 2011 sounds like the coils is not in the gap right did you shim it when you re coned? got it reconed from somebody else , but i dont think its shimmed any DIY to correct it ? the shims are only used when gluing the spiders and the foam down to keep the coil centered in the gap when the glue sets you take out the shims and glue the dust cap on if it was not shimmed when re coing the coil can be shifted to one side and that is bad mmmmkay and there is no way to fix it other then re coning the sub again! Have you ever had your woofers blown?
RooTxBeeR Posted June 30, 2011 Report Posted June 30, 2011 I had cone rattle before, for me it turned out that the dustcap actually was loose, if thats the case, I took a razor, and carefully cut the dustcap off, avoiding slicing into the woofer itself, then once off just used some super glue and slapped that bad boy back on On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
splfanatic Posted June 30, 2011 Author Report Posted June 30, 2011 I had cone rattle before, for me it turned out that the dustcap actually was loose, if thats the case, I took a razor, and carefully cut the dustcap off, avoiding slicing into the woofer itself, then once off just used some super glue and slapped that bad boy back on Type R doesnt have a dust cap , can the sub be reconed with the same parts widout a recone kit?
ALPINE408 Posted June 30, 2011 Report Posted June 30, 2011 nope Have you ever had your woofers blown?
splfanatic Posted June 30, 2011 Author Report Posted June 30, 2011 Sir but alpine imo, doest make a recone kit :? how to do it then :'(
g6ryder Posted July 1, 2011 Report Posted July 1, 2011 Find custom parts I know there was some type r and L7 coils in the fs section www.wooferwarehouse.com
