What HU do you have??
¿ǝɯɐƃ ǝɥʇ
if u have the ski hole covered cut it out i did it in my bmw and it made a world of difference
i dont have ski hole, but i might have precut maybe?
looks a lil different from mines but same concept the factory doesnt cut the ski hole out and it looks like you have the leather flap that covers it if you decide to remove it i had the same in mines and once i removed the metal i just cut the foam behind the seat around the ski hole and used the leather flap to cover it hope this helps
Current vehicle
91 Lincoln T.C.
2 18s trunk build coming soon
for now
2-12s ported in trunk
1000 watt kenwood amp
kenwood deck
18 inch rims
i looked thru your build pics of the bmw and i see the cut out for the ski hole where you ran the wires thru thats what needs to be removed
Current vehicle
91 Lincoln T.C.
for now
kenwood deck
18 inch rims
TNX A LOT MAN, found it and pushed it out
hopefully it will help. BTW, does it matter which way i will face subs and port? towards trunk or towards hole?
there ya go :good: honestly its all up to you i had 2 15s sealed so it sounded better towards the trunk
Current vehicle
91 Lincoln T.C.
for now
kenwood deck
18 inch rims
Vehicles will differ, but most cars prefer it facing the trunk.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
another small problem.
both subs are D4, so they are wired down to 1ohm, however, with multimeter it shows that it's 1.5 ohm load.
I set amp gain to 34.6v ( square root of 1200 times 1 ohm). is it too much?
also
how should i set other gains?
Level: (.2v - 9v)
Phase: (0-180' degrees)
Subsonic: (15Hz - 50 Hz)
Low Pass: (35Hz - 250Hz)
Bass Eq.: (0 - 18db)
i played decaf's money man and it hit really hard. but amp gets really hot too
  • Who's Online   0 Members, 0 Anonymous, 1287 Guests (See full list)
