Hi , I have a problem with my amp (aq1200d running 2 sa-12" 's) . When I turn up the volume my clipping light on the remote start to light . The gain on my amp is at half way , and even if I put the the remote at the minimum it will start clipping at 44-48 depending of the song . I have voltage drop , and my headlight dim . Some people told me that was a bad ground , some told me to do big 3 , and other's upgrade the batterie or the alt , or put a 2 farad cap also ( I know cap are bad ) . So I need big help here . Btw , I have an pioneer HU deh-4200ub. I don't have much money to spend on that .
2001 civic dx
2 X sa12's "
1 X aq1200d
Knukonceptz 4 gauge , rca
uh its because your head unit is clipping. set your amp up to not have to turn it up so far.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If I turn the gain up on my amp , it will be clipping before 44 maybe 40 . Depend on how much I turn the gain up .
Edited by max785
2001 civic dx
2 X sa12's "
1 X aq1200d
Do you have $140 bucks to spend? They're still on pre-order, but one of these (click here) will help you set your gains right and make it so you're no longer clipping
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
did you completely disregard what i said? your head unit is causing it. do you have the loud or any of that stuff turned on/.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yea the loud is off and the Eq is flat :o
2001 civic dx
2 X sa12's "
1 X aq1200d
if you'r talking on the HU the bass level is at 4 on 6 and the sub level setting is at 0.
2001 civic dx
2 X sa12's "
1 X aq1200d
turn bass level to 0, thats likely the culprit
use sub level, never bass level if you want/need more rca voltage
if you are using stock speakers on headunit power than obviously you can only turn them up as much as they sound good, but headunit should go up to mid 50s to get full voltage out of ur headunit with everything at 0/flat
incase you didnt know, u can set your gain with the remote knob... basically turn the knob to 3/4 up, headunit at max clean volume and play a few of the loudest songs u will ever play. simply turn gain up til the light flickers solid red, but doesnt stay red. then when u go to use the stereo daily u have a bit extra knob turn for quiet songs to turn up and you have alot of room if a song is heavily clipped or very loud and you can back off. just never go slight past flickering and youre good. every song will be different, so it will clip at different knob settings all the time
Edited by Decaf
so I put the bass level at 0 and the sub level at ?
2001 civic dx
2 X sa12's "
1 X aq1200d
