SubaruBassPro Posted July 2, 2011 Report Posted July 2, 2011 When choosing an amp should i meet or go a lil greater than the rms rating or the peak rating? Looking at 2 Obsidian Audio 15"s
__d_a_v_i_d__ Posted July 2, 2011 Report Posted July 2, 2011 those are rated at 600 rms ? whatever your comfortable putting the subs through . like a sundown 1500 should be fine Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
kam311 Posted July 2, 2011 Report Posted July 2, 2011 Don't ever worry about peak rating, it's a loaf of s***. go by rms and to be honest I'd stick with brands that are known to do rated. Will price be a factor? The aq1200 would put this subs right at their rms, and you wouldn't need to do much more than a big 3 upgrade in order to run it. I'm going to say that's your best choice probably, even tho those subs at a tad underrated. If you don't like that amp look into some other amps that do 1200-1500 watts rms sundown, dc, planet audio, hifonics brutus series, Rockford fosgate, crescendo, kicker.... The list goes on forever! Just depends on your budget and remember in most cases o it sounds too good to b true, it probably is. P.s. Obsidian will also be releasing amps soon if your not in a big hurry i'd wait to check them out so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
