2011 Jetta Build - 2 15's, AQ amps, Rockford mids and highs
More pictures?? Why not.
Fiberglassing the dash kit.
Big 3 with Yellow Top
I have big hands and I could get my wire throw the same place as your mates car. it is easy as pie.
here are the pictures
here is the atart of with the boot where you feed the wire throw
you remove this panel to make it easier to see the wire coming throw
this is the wire fed throw, you feed it throw this side of the boot
then you will have the wire throw on the other side of the boot
remove the kick panel
that little circle bit above my finger is a hole where the wire goes throw and your done
you can see the hole behinde the rca's
here is a better picture of the hole for ya
I know there is one there, it is in every vw I have seen. so its not hard to find and there you go and now you can fix the wiring up better now good.gif
did u not use a wire harness and looks good so far
No I did not for two reasons.
1. The car is brand new and I couldn't find a harness that fit it.
2. Since everything is running to amps I didn't REALLY need one. The RCA's run to the amps. So all I needed to splice was the 12V constant, 12V switch, and the ground.
Out of curiosity where did you get the switched ACC from in this car? I know the Can Bus is very sensitive in those cars.
Bone Stock 2006 Dodge Magnum SRT-8
the little leaver for the bonnet pulls to the right, you do not even need to pull it at all
I probably could have, but I couldn't putt the boot off and didn't feel like spending hours at it. My way should still work.
No I did not for two reasons. 1. The car is brand new and I couldn't find a harness that fit it. 2. Since everything is running to amps I didn't REALLY need one. The RCA's run to the amps. So all I needed to splice was the 12V constant, 12V switch, and the ground.
Yea I found it weird that they dont have a specific switch wire. I tapped into the fuse block with a small wire. Do you see any problems with that?
Sanded down and fitted. Rage Xtreme next :drink40:
never said it would not, just the extra work is all, oh and as far as I remember its the yellow with a red strip or brown with red strip wire for the ignition irrc but do not quote me on this as it might have changed in the newer models
I dont know I looked online and it said it didnt even have an ignition. It turned on some other way :shrug:
Also the boot running to the door on this Jetta were very tight to the existing wires. It would have been hard to have even fit a run of 16ga in there.
Diggin the build So Far :clapping:
Im surprised at how clean the metal part of the door panels is, clean and simple
In my teg getting the wires to the door speakers also sucked, they are the same way as the ones on the vDub. ppl sometimes drill into the plug and then run wire thru there but fuck that im not messing anything up
funny how hes stuck with that deck for a while lol looks clean, i was hoping it was done already by the time i got to the last pics
Keep it up, looks good so far!
Thanks man :drinks:
The doors suprised me too. The inner and outer skin are almost completely airtight. Every hole was plugged. I think they use that trapped air for sound dampening and maybe insulation.
