make sure all of your wiring is secure and connections are not loose. i beleave mechman alts make the rated power at 8000rpm (not engine rpms, but alt rpms)
remember alt rpm to engine rpm is about 3:1
so that 2000 rpm is actually around 6k alt rpm and since its a special order alt maybe the pulley could be smaller than a regular alt so therefore yeilding more output. alt rpm is most likely out o the question .
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
are you sure you set the voltage right you could be killin the batts. what kind of batts are they and 12v or 14v
alright, was just trying to deduce the solution to your problem.
maybe some extra runs to the rear bank?
-just read the whole post i see you said running kca. kca is rated for 250 amps ( i also am running 0 gauge kca), you are running considerably more than that. if you do 2 runs from the alt to the batt and 2 grounds from alt and then ground alt to car you may see some increase in performance.
i only had 2 runs before adding 2 mroe recently, it didnt change a single thing. will more runs help? yes forsure but is that whats causeing me to drop to low 12s, high 11s? no.. deffinatly not IMO
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
so you already have 2 pos and neg runs from the alt?
He has 4. In the first post:
hokay, my electrical consists of, [...] 2 runs of + to rear 2 runs of - to rear [...]
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 1442 Guests (See full list)
