hokay, my electrical consists of, a 425A mechman alt, vbcm ( set to 15.2v) 2 runs from alt to front bussbars, 2 runs of + to rear 2 runs of - to rear and 3 G31 batts ( not sure the name, but they is big)
equipment, AQ3500.1 @.5 and maybe 600rms for mids/highs
now, when im playing at a "decent" volume, like 3/4 volume i only drop maybe... .4 volts which isnt bad
now, when im playing full tilt i can drop into the mid/low 12s most times, which IMHO shouldnt happen, with that much alt. power.. i should see much voltage drop i dont think
theres no belt "dust" around alt or no squealing happening.. just not sure why it drops soooo low!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
also, yes it is reved when im playing.. 2000rpm or more
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
make sure all of your wiring is secure and connections are not loose. i beleave mechman alts make the rated power at 8000rpm (not engine rpms, but alt rpms)
what brand of wire and how are you connections?
all connections are solid . then run at least 4 runs of 0 + to the rear and 2-3runs of ground from the front battery/engine ground to the rear battery
then 1 -2 more short runs of ground within a foot of the rear battery
also have you checked resting voltage at the batts?
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
ive went over wiring COUNTLESS times, all tight and clean. using knu kca wire resting voltage is 12.8
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   1 Member, 0 Anonymous, 2330 Guests (See full list)
