I was looking up prices on AudioSavings and found ths Sub/Amp Combo, now I don't know alot about car audio so I thought this would be a good place to ask a few questions.
1. If this deal is good would I need to get a better set of speakers(+amp) to upgrade from the stock speakers I have now, which I think are blown.
2. Will I need to buy any extra accessories, or upgrade my battery/alternator?
If I need new speakers+amp my budget is around $300, If you know any good combos for them.
Thanks to anyone who helps.
I'm new to everything audio, so take it easy on me.
1992 Honda Civic CX Hatchback
K24a2 Swap
Thats a big upgrade id say you be needing
1 box a bunch of screws for subs/holding amp down
300watt 2/4 channel amp and replace the stock blown stuf with some nice 30-40 dollar coaxial/pioneer kicker ect ect ...
an amp kit to add a second amp
some knowledge of what goes where and how and you should be good.grab a voltmeter while you at it and if you dippin low into the 12 grab a small battery ...you shuld be set then buddy.have fun.
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
the amp does around half at 14.volts i think i had the 4000d and my bro has the 3000d
rated at peak rms around half.. its a solid amp id take it over audiopipe
ive tried a apsm1300 1000rms@1 ohm but it woldnt do it clean/without electrical
SuperBass
i would not recommend a kit like that as ive never heard of quantum audio and i dont know if its any good or not and its not the best deal for a setup like that. for the speakers you can just get some coaxials and run them off the headunit just like the stock speakers. for a setup that small you wouldnt need to do anything else besides you could do you big 3 just as a precaution.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
well thats a 1500 w rms setup but theres only going to need be 750wrms for break in of the sub..
i have and had the qca mono amps soldid^^^.
the subs i have never tried or had any experience but im willing to give 1 a try look out for my yutube up date it should be coming up soon...
OP when or if you get to put that amp @ 1 ohm be sure to get you electrical system up to par ..but for the first few months you shpuld be fine...should be loud
SuperBass
Thanks guys on the fast replys.
This is an upgrade from the current 100watt sub setup I have now, just looking for some more thump.
@kicker_god Thanks for the concern but this is just for me to mess around and learn more about car audio.
K24a2 Swap
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
