2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
I'm an electrician by trade and even though 12v is different the theory is the same you have a circuit .(amps being the load) the easyiest way to think about electricity flowing is like water. It will take the easiest lest restrictive path copper is a way better conductor of steel (frame) the frame will work but dedicated grounds are best look at the top people that are loud and tell me what they do. I have 10 runs and need 2 more but I only drop .2 full tilt on 12k clamped watts you should be ok if it drops bad add the ground runs if not then your fine. I also ground to frame front and back and from alternator bracket
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So I managed to find a post where somebody had emailed JL Audio about grounds and they said that even on a full-frame vehicle like a Suburban the resistance of the frame is only as good as what you'd find with 4-gauge wire. So I'll stick to running dedicated ground wire to the front.
I think that's a load of bologna man. Most of the guys you see around here are grounding to the frame myself included. I used to ground to the front, but after finding the real cause of my amps blowing the hell up I moved the ground back to the rear and it's disco.
Why were your amps blowing up?
Bone Stock 2006 Dodge Magnum SRT-8
i think u will be good bro
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
U should be fine. Talk about scared I have 10 runs with no fusing lol as long as you secure it and take the time to avoid hot spots and other potential hazards you will be golden.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Brake lines do not heat up and u are plenty far away from that manifold. That welding cable will handle heat just fine, so no worries
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Looks great man. I've yet to seen one of these new Tahoes in the street.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
Now thats the 2 bolt method i mentioned earlier - didn't it feel nice and cheap lol!!
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
