2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
Def gonna have to travel out your way to hear this when ur done
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
I say you enter the 1x show in sanjo and burp it. The subs can handle it mine only have like 3hours play time and are very stiff still. See you there
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I vote video of 5% flex
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
Merzbow, i will be ordering a dual alt bracket from DC power this week, and running a 300 amp alt seperate from the stock alt like your doing with your three, how do you have your seperate alts wired up so they "turn on" with the truck amd "turn off"
i will only be running a single extra alt
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
DC power will give you a harness with a relay, these are the instructions for how to hook it up:
https://support.dcpowerinc.com/index.php?/Knowledgebase/Article/View/4/0/installation-guide-for-relay-harness-with-blue-sense-wire
The tricky part was finding a place in the fuse box. I could not find an unused fuse location that had power running to it and was ignition-switched, so I had to take over a used fuse location. The fuse on the relay wire is 5 amps, but the lowest switched fuse location I could find was 10 amps, so I just switched the 5 amp fuse with the 10 amp fuse. This should be fine since I'm sure the relay and the relatively thick wiring used can handle up to 10 amps without catching on fire (in the event of a short).
I'll get you the exact number of the fuse location I used, hopefully the layout should be the same on your truck.
awesome thanks! im ordering my bracket today since they confirmed it was in stock, are your secondary, third and fourth alts the 4 pin oval connector? thats what my secondary alt will have so i need that harness.
