aq1200d strapping
Kush Killer
so my new build consist of 4 sa_8s and 2 audioque1200d strapped @ 2ohm for 2500 ish watts... now i guess my question is, it has 4ga inputs for power, when i was running a single aq1200d on fi q 12" i had 1/o power and ground with a reducer.. im know 1/0 is good for 300 amps, which ill be right about 320.. so im assuming i should jsut run 2 runs and reduce as previously done? This will be my first time "strapping" amps.. ive always jsut used 1 amp... so any other input would be greatly appreciated! thanks
One run should work. On music amps rarely come close to their fuse rating.
Big 3 with Yellow Top
well i dont have anything installed yet, waiting for my 4 sa-8s to get here along with,my other aq1200d, and starting on the enclosure this weekend. The truck will also be a 14v system (16v charging) with 2 xs power d1400's and a 270amp mechman alt.
oh and this is 98% for music, i say that b/c i may try sum burps jsut to see what kinda #'s it will run.. def. no comp though..
Should be fine as long as you put a battery in the rear near the amps to support some of that current draw. But with that electrical you should be fine on voltage.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
