nickers Posted July 15, 2011 Report Posted July 15, 2011 as the title says the alternator stopped charging the battery yesterday. i started the car in the morning it was working, then stopped it, worked on it for a bit and when i turned it back on it was no longer working. i didnt touch any existing wiring i just ran my 0 gauge from the battery terminals into the car. big 3 is done, all grounds are good, stock and 0 gauge power wires secured. what could be the problem? help is appreciated. chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
zx10intn Posted July 15, 2011 Report Posted July 15, 2011 have you clamped it to be certain its the alt and not the battery? 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD
nickers Posted July 15, 2011 Author Report Posted July 15, 2011 i do not have a clamp, however the battery is only about a month old. i would hope that is not the problem. chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
vettedude102 Posted July 15, 2011 Report Posted July 15, 2011 One way to test if it's the battery or alt is if while your car is running unplug your battery then if the car stays running the alt is good. 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
nickers Posted July 15, 2011 Author Report Posted July 15, 2011 and if its the alt and it shuts down is that going to be bad for the car or?? chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
OLDSKOOL78302 Posted July 15, 2011 Report Posted July 15, 2011 take it to auto zone and let them test it. HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
nickers Posted July 15, 2011 Author Report Posted July 15, 2011 ive taken it to autozone they are a bunch of jagaloons they said it wasnt working after i put a new regulator and bearing in it, i took it home put it in and it ran 14.7 volts. this was a couple of months ago however its ran strong at 14.5-7 volts even up to yesterday. chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
Hugh G. Rection Posted July 15, 2011 Report Posted July 15, 2011 start your car. once its running disconnect the battery. if it shuts down, the alternator aint alternatin' no more. Owner of BigAss Ports
vettedude102 Posted July 15, 2011 Report Posted July 15, 2011 start your car. once its running disconnect the battery. if it shuts down, the alternator aint alternatin' no more. Thanks lol. Shouldn't hurt the car 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
nickers Posted July 15, 2011 Author Report Posted July 15, 2011 alright ill go check right now. if its pooched ill be pissed, it was my little frankenalt chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
