I have a modded tarantula 4000d and whenever i turn my car off(radio turns off to be more specific) the subs play a single bass note when the amp shuts off(thud). The guy that modded the amp said to put a relay.... and then he said to just wire my remote to the yellow ignition.... But wouldnt that mean i couldnt listen to any music with the car on Accessory mode? I guess its not a huge deal but would kinda suck when i vacuum my car or just want to listen to something without pissing away gas money.
Thanks
Also its not a ground loop like ive been reading about...he said the amp didn't have a turn off relay, or he took it out for some reason
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/3920448/vpcsid/0/SFV/30046
pop stopper
http://www.amazon.com/Stinger-SGN20-Ground-Loop-Isolator/dp/B002ZRQ3PW
ground loop isolator
both will work, neither will affect SQ
and yes i know the second is for ground loop, but it will still get rid of the pop
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
yup that should do it ^ ^ ^ ^ id go with the stinger IMO thats what ill buy if i ever have that problem
sht i didnt even click on the second one, the first one is the one ive always hear about :pardon:
Also, could install a cheap switch in your amps remote wire, and shut your amp off before shutting the car off.
2 advantages, no more popping, as well as being able to have your sub setup on whenever you want, while still being able to keep the head unit on.
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
OP if you turn off your radio and it still pops even if the car is on, i had the same issue. for me only the items i posted stopped the popping. i tried a long list of things to get rid of it, and the stingers were the only thing to do it.
Thanks guys, it pops if I turn it off while the car is on too, and if I have acc mode on and start the car.. Doesn't pop when I start the car from off position
  • Who's Online   0 Members, 0 Anonymous, 1599 Guests (See full list)
