BATTERY SPEC?
I tried searchuing and came up with nothing, so if such a topic exists i appologize for repost.
I dont know so im would like to find out, what are the ideal batteries to use for car audio? not brand specific, im talkin about specification wise, like what group number batterys, are cca's important? is reserve cap importan? or more important? thanks for any knowledgable info.!
for instance...
BCI GROUP TYPE. CCA @ 0F .CA @ 32F .CA @ 80F .RESERVE PLATES PER BATTERY.
XHD-31C. 1000. 1250. 1435. 200. 132.
the amp hours and the max amps are most relavant in car audio batteries. check out the xs power section on here and you should be able to find a chart there that shows which battery is good for however many watts
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
ok i understand that, but how do you figure those out on a battery OTHER than a xs power batt? the thing is, im planning to switch over to a 14v system (16.8 charging) in about 3 months.. after im back from my honeymoon and have a few extra dollars saved back up. so for the time being im stuck on 12v system, and can get a good deal a the batterys with those specs i posted above. i compared them to optimu yellow tops and these have those beat by sum decent numbers.. plan was to run 1 under hood and 1 or 2 in back.
  • Who's Online   1 Member, 0 Anonymous, 1310 Guests (See full list)
