KeepItLow91 Posted July 23, 2011 Report Share Posted July 23, 2011 Was going to start on my box soon but found a slight problem when I did a mock-up box. I'm doing a single 15" in a slot port box. Sub front port front, only problem is my trunk has a stupid design where the edges kind of round off where the trunk meets the cabin which will put about the top 3-4 inches of my port behind part of the trunk and only like a 2-3 inch gap from the box. Due to lack of experience idk how big of a problem that is but common sense says it will fuck the airflow up pretty bad. Could I do sub forward port side or does that reduce output horribly? Kind of stuck here and don't know what to do! Due to testing with my shitty prefab system that I currently have, facing the subs towards the cabin is the best choice by far which is why I'm really wanting to keep my 15" facing the cabin. Link to comment Share on other sites More sharing options...
tdc3187 Posted July 23, 2011 Report Share Posted July 23, 2011 Can you turn the box upside down so you have sub front port front with the port on the bottom? Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/ Link to comment Share on other sites More sharing options...
Tarball Posted July 23, 2011 Report Share Posted July 23, 2011 Was going to start on my box soon but found a slight problem when I did a mock-up box. I'm doing a single 15" in a slot port box. Sub front port front, only problem is my trunk has a stupid design where the edges kind of round off where the trunk meets the cabin which will put about the top 3-4 inches of my port behind part of the trunk and only like a 2-3 inch gap from the box. Due to lack of experience idk how big of a problem that is but common sense says it will fuck the airflow up pretty bad. Could I do sub forward port side or does that reduce output horribly? Kind of stuck here and don't know what to do! Due to testing with my shitty prefab system that I currently have, facing the subs towards the cabin is the best choice by far which is why I'm really wanting to keep my 15" facing the cabin. Since you are still in the planning/design phase you could switch to round port and place the port where you want it. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
KeepItLow91 Posted July 23, 2011 Author Report Share Posted July 23, 2011 Just threw together a design with two 6" wide ports at 25" length each. Is 11.33 Port are per foot/56.52 Port Area good enough for a 5 Cu Ft box after displacement? Link to comment Share on other sites More sharing options...
KeepItLow91 Posted July 23, 2011 Author Report Share Posted July 23, 2011 Can you turn the box upside down so you have sub front port front with the port on the bottom? Naw my max dimensions are 17" tall, 34" wide, and 23" deep. I don't have shit to work with really lol Link to comment Share on other sites More sharing options...
