D975?? whats that? a batt?
2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers
BC 264 stage 2 cams
full head build with BC Valves, Retainers, and springs
Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)​Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK
I see for the trunk? wouldent it be bad to put one in the trunk if i have stok batt up front?
BC 264 stage 2 cams
Do you have a voltmeter? If you stay at a constant voltage, say 14.4v, a capacitor should help with the rapid current spikes that the alternator/battery do not have time to supply power to...
Think that's how they work atleast :P
Or take the money that he would be wasting and put it to better use.
If his voltage drop isnt that bad, then something as little as a D975 Or D925 would be better of then a cap, In my opinion.
He has no use for another battery if he is staying at a constant 14.4v, and adding one would not fix the problem, which is caused by the charging system not being able to supply power at a rapid spike... Which the capacitator would be able to do... IMO...
I have done so many times and its never hurt a thing, But then again if you ask that question to someone else you can get a totally different answer.
Yeah i see how about a capkiller?
BC 264 stage 2 cams
if im at a constant 14V's right?
BC 264 stage 2 cams
If your at a constant voltage without any voltage drop. I mentioned 14.4v because many stock charging systems charge up to it. My truck charges at 13.6v, so if I maintained 13.6v with a load on the system, and still had dimming lights, I would look into a capacitor.
  • Who's Online   1 Member, 0 Anonymous, 805 Guests (See full list)
