Alright ill try to se if i can find one
2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers
BC 264 stage 2 cams
full head build with BC Valves, Retainers, and springs
Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)​Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK
Do you have a voltmeter? If you stay at a constant voltage, say 14.4v, a capacitor should help with the rapid current spikes that the alternator/battery do not have time to supply power to...
Think that's how they work atleast :P
Or take the money that he would be wasting and put it to better use.
If his voltage drop isnt that bad, then something as little as a D975 Or D925 would be better of then a cap, In my opinion.
He has no use for another battery if he is staying at a constant 14.4v, and adding one would not fix the problem, which is caused by the charging system not being able to supply power at a rapid spike... Which the capacitator would be able to do... IMO...
BUT, he wouldnt be at 14.4v constant..... so your whole theory is flawed...
just get HIDs from DDM tuning... problem solved
Edited by Team_DC-Derrick
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
lol whys that?
BC 264 stage 2 cams
lights dimming = voltage drop.... you cant charge at 14.4 and have voltage drop to 14.4.... you are probably dropping down to the mid 12s, where your battery floats at....
just get HIDs and you wont notice it anymore...
ddm tuning has cheap ones..
adding a second battery in the back will help a TON more than a cap.... the really expensive 500+$ ones are really the only caps that would remotely help...
Team DC Audio
so adding a second batt wouldent conflict with the stock batt up front?
BC 264 stage 2 cams
i would replace stock as well, to a kinetik or XS batt... that would help out a ton vs the stock one anyways..
Team DC Audio
alrighty
BC 264 stage 2 cams
but it would be cheaper to get the 45$ kit from ddmtuning for HIDs...
i have bad voltage drop, even with all the batts i have, i just dont have enough supply vs demand... and i know a cap would be useless in my case, i switched to HIDs and problem went away...
Team DC Audio
