qu1cks1lver56 Posted July 27, 2011 Report Posted July 27, 2011 I have a stock CS130 on my truck in the factory location, I fabbed up a CS144 on the other side of the motor and have been using just it. I plan to add a second CS144 in the future but for the meantime would it be okay to hook the 130 up along with the 144? First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
qu1cks1lver56 Posted July 28, 2011 Author Report Posted July 28, 2011 No one? First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
armykyle1 Posted July 28, 2011 Report Posted July 28, 2011 fuse and let it eat TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
audiofanaticz Posted July 28, 2011 Report Posted July 28, 2011 You will be alright. Just make sure to wire the plug correctly for the 2nd alt. The cs144 is a larger case alternator, usually are 140amps. The cs130 alt is a smaller case alt and normally are 105amp units. Both alternators use the same style plug iirc, also use the same groove pully (however dimensions of the pulleys maybe differ) and due to the 12oclock and 6oclock mounting ears on the cs144 alt, it will make adding it much easier. Also make sure to use a piece of power wire to connect both alternators together on the positive charging stud on the back of the alternator.
qu1cks1lver56 Posted July 28, 2011 Author Report Posted July 28, 2011 Okay thanks guys. I wasn't sure if it'd be fine to use them both at the same time since the 130 never seemed to do the voltage the 144 does. I'm pretty sure I have the plug wired right. Sense wire and the other pin for use without the light. I'll throw a fuse between the 2 and connect 'em together this weekend and see how it does. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
qu1cks1lver56 Posted August 10, 2011 Author Report Posted August 10, 2011 Hooked up the CS130 along with the CS144 yesterday, voltage is much better. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
