The Best Deal i can get on Resin? + fuse positions/size + Wire types.
I have a couple questions, my system is finally coming Together.
If u help me one one or all I will <3 U 4 ever. :drinks:
-Kicker Warhorse 10k rms "set at 4k daily N 10k burps" at next years Comp at Gibralter Trade Center.
-Kicker Solo x 18 "4 Gauge Speaker Wire"
- Enclosure Info:8.2 Cubic ft after port and woofer Displacement. 100" Port area, 11" deep Port Firing Into a 22" High Horn 8" wide opening. Fully Braced, Also going to be double layered, and walled off "Correctly" into a zx3 Ford Focus Hatch.
-X4 Kinetik 2400's "on the way"
- 270 Amp Iraggi Alternator, The upper series "High Output at Idle"
-Some KnuKoncept wire...
Ok, so since I have a 270 amp alt. AT MOST Im gunna be sending my Battery Bank 270 amps. So Is it ok too just use 2 runs of CCA wire from the front too my bank in the back? Instead of spending a crap ton on 2 runs of Ofc.
Ok in Reality CCA takes a max of 250 Amps Ofc is 300 amps. Instead of buying one ofc wire and having max 300 amps and spent $80.00. Why not do x2 CCA and have max of 500 amps for $25.00.
My bank allthe way to my amplifier will be ofc. Now Instead of doing a Buss bar across the batterys, I wanna do X3 Power wires from Battery #1-#4 And into the 3 Inserts on the amp. On both - and + of the Battery Bank. IS this okay or will I be loosing power, is this better or a worse outcome? its DEFFINITLY
the expensive route, But Im going for the Wow affect, as well as loudness.
IF I run x2 0 Gauge CCA wire From My270 Amp alt Too My Pos. Battery Post on My Starting Battery. What fuse size's do i use?
What areas between starting battery-Batter #1-4-Amplifier. I want this too be a long term system, im doing EVERYTHING emaculant and solid.
What is the cheapest Resin I can coat my box with? I need a cheap But Relaible Brand. I hear it absorbs into the mdf Very well, and hardens it into somthing as dense/Stiff Like Cement, Is this true?
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
Ok i just got a KILLER deal on CCA for a buck a ft, Instead of just 2 runs from the front too my Bank, Im gunna go ahead and do x3 runs just too over kill it.
If i do this what size fuses do i use on the Run From strt batt. too the bank and on too the amp
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Bump :clapping:
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
pls
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
If I understand what you're asking, you fuse for the wire. So fuse it 250a at most.
Find the current carrying capacity for the wire and fuse it for that.
Just make sure you are getting a true 1/0 CCA and not 4 gauge with a huge jacket.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 4726 Guests (See full list)
