RyanJ Posted July 30, 2011 Report Posted July 30, 2011 Wassssssssssup peeps! It's been a while since I posted and I hope everythings going well for all you bass-heads out there. But anyways, so I got my Single SA-12 D4 and my AQ1200D. I just wanted to confirm that I do buy a 4 gauge wiring kit to wire it all up, correct? And I'm going to buy my second SA-12 D4 soon eventually, should I just use the 2 subs off of 1 AQ1200D? Or could I buy another aq1200D and run 1 amp for 1 sub. Thanks guys!! MOB-MOBILE: 2005 Honda Accord 5-Speed System: (1) Sundown Audio SA-15 (1) MB Quart ONX1.1500D (1) Kenwood KDC-248U Speakers: -Rear Dash: (2) Clarion SRQ6932R 6x9's SOLD New MOB-MOBILE: 2011 G37S Sedan System:TBD Instagram (18+) : DabsWitaBudget415
kam311 Posted July 30, 2011 Report Posted July 30, 2011 Well the d4 will be wired to 2ohms so 4 gauge will be plenty! And actually 4awg is good for 1400w or so, so as long as it's a good 4awg then you'd be fine at 1ohm with the two subs. You will get the same output with one amp as you would with two amps since you have d4 coils man. Because a single d4 would wire to 2ohm so 1sub at 2ohm on one amp =600w or so + another sub @ 2 ohm on another amp = 600w so your at the same output as you woul be with just 1 amp at 1ohm so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
