Hey guys, just wanted to post this vid on a test i did today, this little amplifier surprised me a lot, it definitly does rated power if you can keed the voltage high, i don´t know how much distortion it had tho, but still got some nice results, enjoy!!
Specs:
Class D Power Amplifier
1 Ω Load Stable
Overload & Overheat Protection
Variable Low Pass Electronic Crossover
Variable Sub-Woofer Volume Control
Built-in Variable Shift
AP-10001D
• Power Amplifier: 1000 Watts
• Channel: 1 Channel Class D
• Frequency Response: 8Hz - 200Hz
• Signals to Noise Ratio: 70db
• Bass Boost: 30-80Hz
• Input Sensitivity: 0.2-5V
• Subsonic Filter: 5-50Hz
• Low Pass Filter: 40-180Hz
• Output Power (RMS):
1 Channel @ 4Ω - 300W
1 Channel @ 4Ω - 700W
1 Channel @ 4Ω - 1000W
• Dimension: 278x176x55mm
http://www.youtube.com/watch?v=de7DoQwOld0
Edited by fecupe2001
Thanks a lot boss, i dunno the amount of distortion we had at the moment of this test since i don´t own an O-scope , but it was fun to see this kind of results, not bad considering it´s a 120$ amplifier if i´m not mistaken :)
