I would not recommend cadence 1/0awg unless you want cca, even if it not cca it's damn close, and anyone that has a true 1/0awg ofc wire and compares it to the cadence then you will know. It physically does not weigh enough to be a true ofc and the strands are brittle and break easily when you tighten them down in the amp. I don't give a fuck what anyone says, the cadence isn't a true ofc. But I'm sure it would be just fine in this case, for what you need... I'm just saying don't buy cadence expecting a true ofc wire cause it defiantly isn't
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
dam the cca is out of stock lol -.- ...
2001 civic dx
2 X sa12's "
1 X aq1200d
Knukonceptz 4 gauge , rca
Then get a decent ofc 1/0 welding cable. It should cost much more
so far...
I'm not possitive on the exact numbers so I hope someone else chimes in! An ofc 1/0 can pull up to 300 amps or so. And an ofc I think can do close to 200 but maybe more like 180. I hope that if I'm wrong someone corrects me
lol , the cca is cheaper then the cca because I live in canada and it's 20 $ for shipping at audio saving.
Holy confused people... :trippy:
I use welding wire 4 my big 3 its chep
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
Okay typo, my bad I meant that a cca wire does around 200amp... And obviously I'm the only person that has ever had a typo and that is worthy of a stupid fucking little sign in a forum. Thanks to the mother fucking English teacher here
so far...
knuconceptz kfk ?
That's a great wire if you've got the cash
so far...
KFK is OFC.
KCA is CCA.
CCA has higher resistance thus the longer the run of wire, the more resistance and the more voltage drop you get. also when it gets hot, resistance shoots up even more.
OFC is pretty much the norm when buying types of wire. more expensive, but can carry much higher loads and keeps the resistance down.
wtf my fault XD It was supose to be the cca is cheaper than the cadence lol .
2001 civic dx
2 X sa12's "
1 X aq1200d
then I'll buy the ofk even if it cost more :P 12 feet is it enought for the big 3 ?
2001 civic dx
2 X sa12's "
1 X aq1200d
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
