Grelko's 84 Chevy G30 1-Ton Full Size Van
Put on the new idler arm, actually bought the proper tool for the job this time lol.
Last time it took about 5 hours with a sledgehammer, but this time I got the "pickle fork"
ball joint/idler/pitman arm puller and it only took about 45 minutes.
Noticed that I lost a couple upper control arm cross shaft shims, but since they fix the camber during a front end alignment, the shop should add/remove as many as needed.
need 1 more 3/4" sheet of the sanded plywood for the bedframe and 3-4 more 1/4" sheets for the ceiling plus a couple L-brackets, replace door seals and driver side window crank.
both of the lower ball joints will be done in the next week or 2, then I can get the alignment, THEN I can finally start thinking about speakers :)
Out with the old, in with the new.
Optimus XL-400w amp 2x 10s IMPP 400w 2x something or other in dash 2x 35w radioshack 8" full-range AcDelco factory radio "frankenstein'd from my dead buick" Dodge seats 1984 Chevy G30 full size 1-ton van "Rust Monster" Progress - around 15% primer/patching
Sold the van in 2014, had it about 75% done, never did get the system in it. Bought a 2000 Chevy S10, still using the same amp/subs. Headunit is XO Vision X538. It's 52x4w, has a dvd player, auto flip out 7" touch screen plus alot more and is a single din.
Got the bed frame back in the other day, a decent sized shelf on each side, hinged half of the bed frame floor for storage underneath and a couple locks so it won't rattle too much if I hit bumps on the road.
Been sanding spots lately, started to hit a few with primer plus the step up in the sliding door part.
Will check over the primered spots for smaller dents/scratches that didn't fill in all the way then, add more bondo and start the process over.
Started the ceiling earlier today.
Should have some pics up tomarrow.
Thanks, the insulation isn't bad, actually half decent sound deadener probably because its about 4" thick, but I had the room and it's cheap so why not lol. It's not too bad in the winter anymore. Also keeps it a little cooler in the summer which is a good thing since I don't have an AC.
I'm hoping to have enough room between the wood and van ceiling for atleast a small layer of insulation there also which would muffle the bass rattling even more.
It's still going to take a long time to finish but, If I get enough done I might be able to get it in some cruises/shows by next summer.
If all goes as planned so far, I should be ordering my first couple speakers by late september early october.
Took some pictures today while working on the ceiling.
coupls packs of insulation
ball joints waiting to be replaced
bit of wood that's left
some spots that have been primered "check old pics to see the difference"
sliding door step
what I've been working on lately
packed up for the night
an 8" speaker just to show the room in the van in front of the area for subs/storage.
Hopefully I'll be able to finish up the ceiling tomarrow.
Looks really good actually man like making small things look like a huge difference.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
slowly but surely I'll get it done lol.
I think I'm doing around 1/10th of 1% per day that I work on it.
Was planning on putting wood down where the step is for the sliding door...
Got it all cut and put in except I kept breaking screws even after I drilled holes, so I'm just going with carpet there instead.
Putting in the last 2 pieces of ceiling in the morning, then probably back to doing body work. Getting some ideas together for the dashboard and doors.
