need a lil help with numbers
if i build a ported box, wat would b the best hertz number to go to for groundpounding bass. as in 32 or 33hz etc... as my signature shows ive go 2 T1D412's and a 1000.1 BD rockford fosgate amp. im gunna end up building a bigger and better system later on but for now id like to work with wat ive got already. thank for the help
Wicked 4 play car club
2002 Chevy 2 door blazer
Real soon setup
head unit: PTID-8920B
subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz
amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using
power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it.
speaker wire: 12awg speaker wire and 8awg for subs
speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference
misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
32-34hz is usually a safe bet.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
is there any way u could give me the best box diagram? if so the widest i can go is 37.5 subs up port back. thank you again
Real soon setup
No sorry bro i cant do designs. :( if i knew how i would do it for ya for free doe. Theres some free designs on here somewhere. I know ramdesigns on here is da ish doe.
This is the one i had for my hdc3s doe I did subs and port same side the 36"by17" side
4.5ft3 with 73in^2 of port area tuned to 33hz should work out for this application.
Height-17
Width-36
Depth-22.5
Port
Width-4.75
Height-15.5
Length-33
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
You could put subs up and port back with that design just put the port on one of the 36"by17" sides
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
go big and tune to 35hz
would 35hz make it hard to breath? i wanna make it to where its hard to breath or theres a pain in your chest when u breath
Real soon setup
you have a blazer you want to tune to 35hz and face every thing backwards. I've done maybe 20-30 systems in my blazer before it got wrecked, back was the flattest, lowest, and loudest to ear. To the meter subs up metered slightly higher
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
yup, works pretty good for my 2 12's
DID U GO SUBS UP PORT BACC OR EVEYTHING BACC?
Real soon setup
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
