couple of questions about the 2002 chevy silverado extended cab.
my first question is why would i have a scraping noise coming from the rear end of the truck almost as if the brake pads were metal on metal. but they arent.
also sometimes my back brakes get stuck. like if im stopped at a red light, when i go to take off the engine will rev but the truck wont go for a second as if the brakes were stuck. could the calipers possibly be bad. also would it be a good idea to flush all of the brake fluid since its probably the original fluid.
my other question is what are the easiest modifications to do to the truck. i know of a cold air intake and dual exhaust i also know about getting a tuner. but what else is there that can be done.
i never popped off the tires and looked but i felt the brake disks on both sides and they dont have any grooves on them. when i rotate the tires this weekend ill look at every thing a little closer
how do you know the pads aren't shot then?
its only been about 3000ish miles since the pads were replaced so they should still be good
check your brake dust guards, I had a place do some work and they got bent in and rubbed against my rotors, simply just bend them back so they aren't touching, couldn't say that's it, but i'd just check it out.
Bills
KwB
Team DC Audio Midwest captain
  • Who's Online   1 Member, 0 Anonymous, 1572 Guests (See full list)
