Ok so I have a hifonics HFI 100.4, Kenwood eXcelon KDC-X395 headunit, equalizer is a PPI ED.Z, and my speakers are 4 rockford T1 6.5 coaxials and two memphis power reference 6.5's hooked up to channels 3 and 4 with a pair of the rockford coaxials. The issue i'm having is that when I turn off my car with the radio and EQ on I get a loud pop on the speakers, the EQ's volume is at 1/2, the amps gains are set at 1/2. A few weeks back I started getting engine noise through the speakers so I checked my grounds and swapped them around a few times only with the same result. I left the ground hooked straight to the chassis of the car. After doing a bit of research on here I learned about the pico fuse that my kenwood and a lot of pioneers HU's have that sometimes blow and start causing engine noise. I grounded my RCA's and it went away but the popping is still there when I turn the car off. Any help would be appreciated, open to any suggestions!
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
you have a ground loop somewhere.
http://www.crutchfield.com/S-xpQ0MQqSkj8/learn/learningcenter/car/noise_suppressors_installation_guide.html
that is a good read. basicly check over ALL your connections and make sure they are solid/not shorting across anything.
also try looking at this one
http://www.epanorama.net/documents/groundloop/
This page is crispy_chick3n approved.
© crispy_chick3n inc
  • Who's Online   0 Members, 0 Anonymous, 1361 Guests (See full list)
