MECHMAN Posted August 9, 2011 Report Share Posted August 9, 2011 Ray will be sending in the unit for testing. Our alternators have a warranty that is good for the original buyer for the period stated at the time of purchase. We always stand behind our products and are always willing to dyno test and inspect our units to insure proper performance. When the alternator changes hands or the warranty expires our customer service does not stop, we will still do our best to keep our products functioning at peak output. In this case Ray is the second owner of this unit and we are not aware of how it was handled prior to his installation. We will be testing and inspecting this unit to properly diagnose the problem and get it resolved even with it not being under warranty coverage due to transfer of ownership as a courtesy to Ray as he has been a good customer. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
RickyFriery97 Posted August 9, 2011 Report Share Posted August 9, 2011 nice to know, i need to clamp both my iraggi 300 amp alts, most likely will be sending them to yal one day for a mechman rebuild Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
AA98hoe Posted August 10, 2011 Author Report Share Posted August 10, 2011 I have a major belt slip issue and low idle issue I added another pulley on my dual bracket and will test tommorrow as far as idle I'm still trying to figure out a solution the unit works great above idle so ill be running it at then next 6 shows I have in 2 months then ill send it back lol thanks again matt Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
EclipseChris Posted August 10, 2011 Report Share Posted August 10, 2011 Since when is voltage the same as amperage? Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback. Link to comment Share on other sites More sharing options...
