XS Power
s3400 or d3400 will fit in the stock tray(s) up front. If you want to do some modding, you can do what meade did and move the ecu back and take out the tray and have a d3100 sit in there but then you have to run new power and ground wires to your starter, engine, fuse box, etc.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
youre welcome bro. Also, since im 99% sure you will ask this, as the "what size batt...." along with "whats the difference between the s and d batteries" are the two most asked questions about xs power. The S3400 comes with top posts in the box so if you have terminals from GM that bolt to the top of the battery using the brass posts, you will want to select this battery. The D3400 comes with screws and a washer so you would only be able to connect power cables to it with a ring terminal on the end.
If your battery has terminals on the side, you will need an xs power i-bar kit. the i-bar 551 and 555 kits are what you will need if you have terminals that bolt to the side of your battery. The 551 is what i use and its great, but the 555 would be easier if you plan to have a crap load of power wire running off the front battery.
edit: you can either call xs power or go to Meades site: http://wccaraudio.com/xs-power/agm-batteries/12-volt/xs-power-12v-3400-group-34-agm-battery.html and get the 3400. I never ordered from Meades site so idk how fast it will ship but i assume fast. Plus his site has better deals on batteries than i paid for my s3400 2 years ago.
Edited by kickass audio
youre welcome man. thats what we are all here for, well mostly all of us. hahaha.
  • Who's Online   0 Members, 0 Anonymous, 694 Guests (See full list)
