got a few questions about the new alt i have ordered plus 14v questions...
Do it at 15.1v cold. The instructions that come with the alt tell you to run car at around 2000rpm and with lights and/or AC on to simulate a light load on the alt. that way you will set voltage output at alt correctly.
If you have the cash do a 14v battery under hood and two in the back and add another if you have too.
Theres nothing wrong staying at 12v either, just do like a S340 under the hood and a D3100 or two in the rear. As you can see you will spend which ever way you go. If things cost about the same I'd run the 14v for the voltage edge.
XSpower safe charging levels
12v batteries 14.4v
14v batteries 16.8v
16v batteries 19.2v
So you see you can set it at 15v range COLD start because as your car engine bay as well as the alt heats up the voltage will come down to safe charging levels. If you have not purchased a stinger voltage meter you should and hook it to the front battery so you can keep an eye on your voltage.
http://67.199.14.11/store/pc/Stinger-Digital-Blue-LED-Voltage-Monitor-11p117.htm
Please use blue locktite on all your threads when mounting alt.
good luck.
Edited by crunkjuice1
I wouldnt set it any higher than 15v.. thats kinda the limit w/ 12v bats. usually cold charging voltage is higher and when ur car warms up itll drop some.. i would set it 15v max with nothing on, cold that way it wont it wont go over 15v, but you could always just set it to 14.4 which is the regular charging voltage for 12v bats and not worry about it.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
lmao if it comes with instructions then obviously just do what it says, i dint know instructions were included haha. and yea your car should be fine running at 14v you just have to be careful above certain voltages you could f up your cars computer / electronics the limit is usually around 16v but many cars are picky.
Setup:
Xs D3400/ Xs XP3000
exactly, id rather just play it safe and keep 12v for the time being, thank you for all the replys, now i just need to find some batts on the cheap
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   1 Member, 0 Anonymous, 1764 Guests (See full list)
