Trying to Tune My Box To 33hz ..... I'm Lost!
dereileak
Hey Guys, well I built a box as large as I could fit in my mazda3 hatch, and now I just need a bit of help calculating the port size on it so I can achieve 33hz, subs are gonna be facing up, and the port will be facing up too between the subs
Data:
1: 2 subs Sharing Same Airspace
2: Want tuned to 33hz and need a square port made of mdf, no round ports
3: Subs May Be Put in normal or I may have them firing into the box with the magnet out, depends if they hit the ceiling in my car, lol
4. These are 2 15 inch subs, so the port has to be able to fit between them, the subs are not going to be right up against the edges of the box
5. Thanks for all your HELP! :D
6. All the measurements in the picture already cut out the mdf wood size, this is the internal measurements of the box, so remember the 3/4 thickness of the wood the port has to pass through
sorry, I have to leave for work right now, so I couldn't get sub displacement :(
Link to the Subs Manual Specs
Gives you an idea of visually how it looks
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Quick Question, does having 2 subs in the same enclosure effect the boxes tuning? besides that there is more displacement with 2 subs?
Pioneer 4300DVD
Does this port get me to about 33 hz? If not what should I change?
Pioneer 4300DVD
problem is the box is a bit small, so to tune it that low, the port needs to be longer than what you can fit.
6.6cuft before displacement, so you might have 5.6cuft after woofer and port displacement (unless you do invert the woofers)
the most space effective ports would be two 6inch round ports, but they'd need to have 90 degree bends as they'd need to be 20inches long for about a 33Hz tune.
no, that port equals a 57Hz tune... <_<
what would I need to do to get that down to 33 hz? when you design a box, do you have to recalculate the removed airspace that the port takes out and take that into factor for what tuning it will be?
Pioneer 4300DVD
Are all these Correct? I used outside box demensions, made the port tune it to about 30 because with the subs in and a little bracing it will bring it to about 33 hz, does this all seem right?
Pioneer 4300DVD
Not enough port area. Also you're not figuring for any woofer displacement which would probably be .20-.25 or so.
You're not going to get enough airspace for those 2 subs when you have enough port for them to work properly in that box without doing some external port. Your starting at 6.62 which before ANY displacements only gives the subs 3.31 ft^3 each which is around what they should be seeing net.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
I am actually going to invert the woofers so they are sticking out of the box, so that fixes that issue, why isnt the port large enough if it gets the box to the right tuning?, its a good amount of area that its going to get to move air freely in and out of the box, dont take this as me being a know it all, I dont know, im just asking :D:P lol
Pioneer 4300DVD
Not enough port area will cause port noise. At 3" per cube it'll be performing like a leaky sealed box.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
  • Who's Online   1 Member, 0 Anonymous, 1226 Guests (See full list)
