Vi sound Posted August 14, 2011 Report Share Posted August 14, 2011 Ok here is my question . i have my amps (AB400.1) strap but how do I wire my sub in paraillel to drop my ohms to 0.5 ? Quote Link to comment Share on other sites More sharing options...
awall1022 Posted August 14, 2011 Report Share Posted August 14, 2011 positive to positive and negative to negative Quote lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over Link to comment Share on other sites More sharing options...
TheyDontWantMusic Posted August 14, 2011 Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Quote Link to comment Share on other sites More sharing options...
Vi sound Posted August 14, 2011 Author Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok so can i do that from outside the subwoofer box or do i have to do it from inside the box ? Quote Link to comment Share on other sites More sharing options...
Vi sound Posted August 14, 2011 Author Report Share Posted August 14, 2011 (edited) if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok this is how my friend had it run he strap the amps and then he took the + from each side of the sub and run it to the master + and the - from each side of the sub and run it to the slave + . at what ohms did he run the sub at ? Edited August 14, 2011 by Vi sound Quote Link to comment Share on other sites More sharing options...
TheyDontWantMusic Posted August 14, 2011 Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok so can i do that from outside the subwoofer box or do i have to do it from inside the box ? you don't want to do that. whats the sub? Quote Link to comment Share on other sites More sharing options...
skittlesRgood Posted August 14, 2011 Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok so can i do that from outside the subwoofer box or do i have to do it from inside the box ? it doesnt matter. do you ave any idea how risky it will be to run at such a low impedance? and how much more electrical it will take? and if the amps fry it will be your fault, cant get mad at the manufacturer. Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
skittlesRgood Posted August 14, 2011 Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok this is how my friend had it run he strap the amps and then he took the + from each side of the sub and run it to the master + and the - from each side of the sub and run it to the slave + . at what ohms did he run the sub at ? its .5ohm but because two amps are strapped together each amp sees .25ohm. Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
Vi sound Posted August 14, 2011 Author Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok so can i do that from outside the subwoofer box or do i have to do it from inside the box ? you don't want to do that. whats the sub? MOAB 18'' dvc1 Quote Link to comment Share on other sites More sharing options...
Vi sound Posted August 14, 2011 Author Report Share Posted August 14, 2011 if you have a 1ohm DVC sub, wire it in parallel, and run it off two strapped amps, each amp will be running at 0.25ohm. Ok this is how my friend had it run he strap the amps and then he took the + from each side of the sub and run it to the master + and the - from each side of the sub and run it to the slave + . at what ohms did he run the sub at ? its .5ohm but because two amps are strapped together each amp sees .25ohm. ok thanks bro . I was not sure becouse my friend just passaway so i am on my own so thanks for ur help Quote Link to comment Share on other sites More sharing options...
