warm subs and not enuff beat
I know alot of racecar drivers that cant install the engine in their car.
I said what i said cause seems people learn more by watching someone else showing them.
When pricey equipment is on the line, sometimes its a much cheaper lesson to just pay a pro to show you.
If you had to rebuild the clutch set in your automatic trans in your car, would you try to learn how to do it from a forum or pay a pro?
I dont need an answer, just food for thought.
Im not against diy.. If i was, i wouldnt do what i do for this forum.
Take your subs out
Go to a local shop
Ask them this...
"im having trouble with wiring my subs in series parallel, can i pay you 30.00 to make the wire connections?"
Tell them they dont even have to screw them down.
Dun
Or save some money by learning how to use his nice equipment.
Nothin irritates me more than people with decent equipment that don't have a clue how it works.
Do it that way we would do it. Test each sub individually. Test each coil on a amp, and measure the coils with a DMM to be sure they are in range.
Done. Saved $30, and learned something.
Take your subs out
Go to a local shop
Ask them this...
Dun
Ray has a BIG POINT... But putting wire in terminals.. Is alot easier than replacing a transmission :popcorn:
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Well.......
This thread says different........
I spent so much time looking at my 2 D4 12's over and over and the way I had them wired LONG before I ever put power to them. Glad to say I've never had to blame equipment for a mistake I made wiring them wrong.
Ummm never once did I blame the equipment bud...
Are u sure you messed the amp up? Wire all subs in parrallel then put a pair to each amp ohm load will be 1 ohm per amp don't strap them if u blew a amp wire all subs parellel to one amp until u can buy a replacement or bigger one. Aq should be able to do .5 all day if your electrical is strong.I think it would be similar output to the 2 amps strapped at higher ohm load. Because of box rise
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Thatsexactly what I did yesterday. And the them switched set from 1 amp 2 the other. Which ever set is on the amp in question the don't sound rigt. I have strong elec. Dc power 270xp alt optima yellow under hood and a firemware agm g31 in back
And I know how 2 wre sieres. And parrell. I have 16 g31 btteries in back of my cadiilac ran in sieries and parrell. The problem was being in a hurry.
How do all 4 subs sound on 1 amp
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
