Daylight
Is that fiberglass? Yep I pulled it back out to glass the inside
Sorry I only took 2 pic when I first started glassing cause I got in some poison sumac a couple weekends ago and between that and te fiberglass I just wanted to get done but I used a half gal of US Compounds this epoxy resin and 3:1 hardner with some carosil thickening agent here and there and 2 4x4 sheets of medium matting lots of 40 grit and 180 grit getting it smooth and a can of primer to stick whatever dust didn't comeout with the van and air hose.
The amp came in today!
Kinetik HC2400 wired in, I know I need another one and a fuse block.
"MOAR" to come building a plate to clean it all up and run wire through.... hope this hold ya'll over for a day or so.
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Beautiful luckly you don't have a drop down hatch, you loose some spl points over the window split due to the seal if your box goes over the window line. Id guess you still do just not as much.
Size and type of woofers? Amp? And I'm diggin the tail lights. :D
actually thank your wrong about that losing cuz friend of mine doing 147 on 800 watts with subs up port back in 2 door blazer tuned to 43 hrz peaks at 49hrz. we used window stripping around the window to seal the window and don't leak no more. the 2 doors to me actually louder cuz smaller cab and there window curves way more than 4 door.
1996 dodge stratus
audiopipe 3k
2 15 american bass xds
10 door speakers threw out car
kenwood head unit.
spl scores from trunk: 147.7db on 2k
extreme out side window-129.2db
kaos 3 min average music-138.3db
148.4 @ 11.91 volts on a 38hz tone errrrrrrrr I need an alternator!!!
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Vids?? Blazers suckkkk for space, check my build out and see how I squeezed (2) 18s in the back :pardon:
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Yea I will get a vid tomorrow and post it up
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
The design is a beast great airflow and still sounds crisp on music
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Nah bro doesn't suck at all everything coming together real good. As for the alt is was thinking that the other day. That's definitely your next move.
I had to get the batt paid $200 for it and 25 foot os 1/0 with a audiopipe anl fuse holder and fuse but for sure an alt is my next move
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
http://youtu.be/f0zV9sstl4E
f0zV9sstl4E
guess its not workin for me :/
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
  • Who's Online   0 Members, 0 Anonymous, 1856 Guests (See full list)
