EBW Posted November 8, 2011 Author Report Share Posted November 8, 2011 Thats cool! I read your using a p400-4, thats a nice amp I had it but honestly think I killed it with starving it from power and possible clipping before alt upgrade :/ Keep up the great work. Yea one of these days an alt is in mix, sound deadener is next before I break my truck w/ flex I'm guessing your blazer has the 4.3 Vortec? They came stock with a cs-130 Alternator rated at like 105a and does about 40 at idle. Look for a AD-244 from a junkyard around here they are 35$ and get a 1-1.5inch longer belt. That alternator does about 100 or so at idle and 145-200 while driving. Cheap fix until you get a good one or hell it might be good enough. That's the Alternator i put in all my s10 buddies trucks doesnt look like its the same, mounting wise Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
Socky Posted November 8, 2011 Report Share Posted November 8, 2011 Looks good man, keep it up. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
EBW Posted November 8, 2011 Author Report Share Posted November 8, 2011 Looks good man, keep it up. Thanks! it's been slow (working alot) but winter is coming and that means in the shop i will be! Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
EBW Posted December 13, 2011 Author Report Share Posted December 13, 2011 Part of my "House Build" Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
crunkjuice1 Posted December 13, 2011 Report Share Posted December 13, 2011 Have you tinkered with your truck on anything? Link to comment Share on other sites More sharing options...
extremeauto Posted December 13, 2011 Report Share Posted December 13, 2011 Part of my "House Build" not to shabby ill have to hear it when i come visit 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing! Link to comment Share on other sites More sharing options...
EBW Posted December 13, 2011 Author Report Share Posted December 13, 2011 Have you tinkered with your truck on anything? I TL a 149.3 sealed on the dash on a 38hz tone Holidays make the cash tight, but bet your A$$ first of the year is going to be awesome, buying that 330A alt from Mike Singer and more Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
1988JimmyRE Posted December 13, 2011 Report Share Posted December 13, 2011 Thats cool! I read your using a p400-4, thats a nice amp I had it but honestly think I killed it with starving it from power and possible clipping before alt upgrade :/ Keep up the great work. Yea one of these days an alt is in mix, sound deadener is next before I break my truck w/ flex I'm guessing your blazer has the 4.3 Vortec? They came stock with a cs-130 Alternator rated at like 105a and does about 40 at idle. Look for a AD-244 from a junkyard around here they are 35$ and get a 1-1.5inch longer belt. That alternator does about 100 or so at idle and 145-200 while driving. Cheap fix until you get a good one or hell it might be good enough. That's the Alternator i put in all my s10 buddies trucks doesnt look like its the same, mounting wise yeah on the vortec engines it's a very simple bolt on, on the older tbi its a very pain grinding and cutting but it is exactly the same mounting wise just a lot larger case BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG Link to comment Share on other sites More sharing options...
EBW Posted December 14, 2011 Author Report Share Posted December 14, 2011 yea I will probably get a AD-244 to replace the stock a weld a bracket to add the Singer 330 tax time Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
mattc3366 Posted December 15, 2011 Report Share Posted December 15, 2011 Builds looking good man! Not sure how much your looking to spend on deadener but my audio technix worked very good in my car. subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch Link to comment Share on other sites More sharing options...
