imupabove Posted August 16, 2011 Report Posted August 16, 2011 I opened it up so I can adjust the gain from inside of the amp because the knobs snapped off. I was able to turn the gains inside with a mini-screw driver. And then this black little thing came off. My friend tried to solder the connection back on. The solder wouldnt stick. Any clue on how I can get this fixed? The amp turned on before I opened this amp up... But didn't test it out on any subs because I don't have any at this time. I know a shop locally where they sell nothing but Rockford gear... and I think they do amp repairs but I'd to see if I can save me some $ first. Let me know if you need to know more of details on the amp. Thank you very much. Quote iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
Azagtoth502 Posted August 16, 2011 Report Posted August 16, 2011 Try again with solder flux. (If he didn't use flux that is) Quote pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
STEvil Posted August 16, 2011 Report Posted August 16, 2011 local electronics (tv etc) repair shop would be a better place to get it repaired. Can you get the numbers off the mosfets for me, or really good macro pics? I need to repair mine.. 5n05hd is the output side iirc. Als there are some 3-legged driver IC's near the caps (that big black thing that broke off) that I need numbers from. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
