DC Sound Lab
I hear u on that I love my 14v batterys I gained so much on the swap especially when doing p&p in meca I use to drop to 11s now its high 13s :-) when I tested 2 9ks at .7 strapped in my hoe my drop wasn't as bad as I. Thought it would be those amps had me scared way to much power I could easily blow my xls with them and did rip the spider on one lol. Good job bro im tuned in for moar pics and vids.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Why 14v? Can you safely run 12v stable amps at 16ish volts or do you just charge at like 15.4 or something.
I realize the 12k isn't stable at 18v, I just don't se why people do 16v systems over 18v if I'm not missing something secret.
Either way though, sexy amps are sexy. 2 9ks or not. :hmmm:
Higher voltage less amperage easier on alts and batterys lower voltage results in clipping if you try and get the same output. What I mean is I can start a song and play it really loud at idle after 15 20 seconds my voltage starts dropping and the amps will clip sooner resulting in stinky subs. Solution keep rpms up let alts do there job and I don't have voltage drop the amps are happy subs are happy I'm happy. This doesn't apply to average systems I think its more like 5k on up. Sorry to thread jack chode
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
yea my average score dropped because i would be in the 14s on a mean bass note sometimes high 13s but thats MUCH better than in the upper 11s-lower 12s
yea but my 12v batteries do not like 15.8 volts which the 12k is rated to run. Rusty said the 12k can do 16.0v but in very short burst. 15.8 is what that amp likes so that amp doesnt even like a 16v system.
i want to get back to my 14v batteries and have run in the upper 15v area. i would have to charge the batts once a month to top them off and keep them fresh though as soon as i turn the truck on
updates will soon to be had once i sell the Yellow top thats in there, the Batcap 4ks and both of my SMDs.
NoFearX18 said:
trainman0978 said:
Sorry to thread jack as well, but a 14v battery charges at what, 17volts almost? I thought the 12k was only 12v stable. Where does it protect? How can you run a 12v amp that is only stable up to like 16ish volts at higher? And if it is stable on a 16v system, it's normally stable on an 18v system. So why go 16v if 18v costs very little more and is just that much better? I'm not bashing or anything just curious if I'm missing something. :P
Got you on that chode. I didn't think you could really keep a battery charged that low and not at the least shorten it's life. Makes sense now, and I didn't know where it liked to be. :cheers:
i cant wait to get my new DC amps for my car im still deciding tho 2 9k or 25k or really see how hard i can run the subs and 2 12ks got 4 x 3000wrms subs 15 to push so probaly can handle them but they are pretty big
sexy tho reall nice work to clean and simple the way it should be car audio doesnt have to be complicated
Ren
AUSTRALIAN DC DISTRIBUTOR AND TEAM DC OZ MANAGER
ren id grab the 9k on 16volts. the 12k seems like a beast but seems sensative lol like big strong girl. unless im missing something and not understanding how it handles power lol
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
chode i wouldnt go with the 14v batts unless u can adjust the output on ur alt. idle voltage should be ~16.5v with the 14v batts... :peepwall:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
the 14v batts want to see 16.9. i plan on getting a charger that i charge them once a month to top them off. the 12k wants to see no more than 15.8 so ill run in that area. it wont hurt the batteries as long as i charge them at least once a month. my truck also wont handle above a 16 volts so that works out for me GREAT. the 12V system is just not working out for me that great
at long as they get charged once a month according to Nathan they will be fine.
Ren
25k?
read above posts
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 2827 Guests (See full list)
