Phoenix Gold Australia's 12x 12" Elite's 24kw - 160.2dB @ 40Hz
Hi Quake City,
I think I understand what you are referring to, and I 'hope' we have planned accordingly to try to avoid this sort of situation. We worked out the progression ratio of each of the baffles according to the combined Cone Area + Port Area.
Hopefully this will make sense...
- the REAR of the Rear Baffle (adjacent to the port) is 80% of Sd + Port Area
- the FRONT of the Rear Baffle (the transition from rear baffle to front baffle) is 96% of SD + Port Area
- the FRONT of the Front Baffle is 100% of Sd + Port Area
The hope is that with the opening areas providing little if any compression, that we won't have as many issues. But I understand you concerns about Series Loaded Port Vs Parallel Loaded Port... And you're right, Sadly we just don't have room in this small car to do a Parallel Loaded Port :( And I just can't bring myself to go Sealed, even if it were louder, because...it's SEALED and SEALED boxes are the DEVIL :P
Appreciate the info!!!
Scott
  • 3 weeks later...
Hi All,
As expected the end of the build was absolutely NUTS. Sorry for not posting progress pics earlier, but we were up against a Deadline to get this thing even
playing, let alone looking half decent. Still lots of work to do, but we made it!!!
B-Pillars taking shape:
Top and Bottom Trims going in:
Posted these in the Member Video's section, but thought I'd add them here too ;)
Hi All,
For those of you following our rebuild I thought I'd put up some videos from our first show. This thing is by no means finished yet, but it is making noise and already tearing itself apart and breaking things!!!
Hope you like them...
Hope you like them!!!
