KenC210 Posted August 19, 2011 Report Posted August 19, 2011 Ok so right now i have the big 3 already with the stock alt. its fused with a 150a fuse from alt to battery. When i upgrade my alt to a h/o should i use a higher fuse rating from alt to battery? Also i will be installing a second battery in the cargo area and the batteries wont be the same type and i will be using an isolator for that application. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
rickyfromthe407 Posted August 19, 2011 Report Posted August 19, 2011 You say its fused w/ a 150amp fuse? What made you decide to do that? I dont nkow what kind of vehicle you have so the 150 might be alright, but you want to make the fuse the same size as the alt. So if your stock alt is 150amp, then yeah a 150amp fuse is what you want. When you upgrade to a bigger alternator, assuming your H/O alt is more than 150 amp, your going to want a matching fuse. When you add the second batt, your also going to want a inline fuse between the two batt pos. Current 4 10"s System! 1/0 Power Wire All Around + Big 3 - $140 Rockford Fosgate T2500-1BD - MSRP $1800 (4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200 XS D6500 $245.65 PIONEER AVH-P5200DVD 7" Head Unit = $430 Soundstream SC-6T Component 6.5" FRONT $60 Pioneer TS-A1673R 6.5" REAR $85 A Bangin system! = PRICELESS!
bumonskateboard6 Posted August 19, 2011 Report Posted August 19, 2011 You say its fused w/ a 150amp fuse? What made you decide to do that? I dont nkow what kind of vehicle you have so the 150 might be alright, but you want to make the fuse the same size as the alt. So if your stock alt is 150amp, then yeah a 150amp fuse is what you want. When you upgrade to a bigger alternator, assuming your H/O alt is more than 150 amp, your going to want a matching fuse. When you add the second batt, your also going to want a inline fuse between the two batt pos. Fuse is to protect the wire, CCA 0 gauge I fuse at 250A and OFC 0 gauge I fuse at 300A. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
KenC210 Posted August 19, 2011 Author Report Posted August 19, 2011 ok so the alt i am looking at getting is either a mike singer or the mechman at around 270a and i am currently using kicker ofc 0ga and if i inline the 2 batteries together wouldnt there be a problem with that cuz one is a diehard gold (starter) and the yellow set in the rear not hooked up yet. the yellow top is temp till i get the xs power. i got yellow top new for $50. so could beat buying it Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
KenC210 Posted August 19, 2011 Author Report Posted August 19, 2011 should i just go ahead and put a 300a circuit breakers for each battery? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
