help tune my box
pantantler
ok i have come up with a couple designs. and i built this one for now..
i would like to tune it in the 32-40 hz range... or if there is a better range for this speaker. please reccomend
subs 2 kicker L7 12 " its what i can afford and already have..
box is 4.93 sf w 30.5 d 22.5 h 15.5 outer dimensions .. made of
3/4 MDF
i cant use 6 inch ports.. none around here for me to get.. so i am limited to 4" aeros
i drew a quick pick to show where the ports need to face out..sry dimensions on the pick are inner measurements.
how many and how long of ports/ or what is best for these speakers..
just some extra info.. i have a single preefab box made by kicker for the l7 12.. that has 1 round port 5" id 11" long
Let me just clear something up really quick and I can get to designing you one...
You put " box is 4.93 sf w 30.5 d 22.5 h 15.5 outer dimensions made of 3/4" MDF"
Does this mean you already have the box made and you're going to modify it to make the ports fit?
And please post the pic you said you drew, I assume the ports are going to be external?
To be honest with you, I think instead of trying to modify the existing box, you could just start a new one... It would be a lot easier.
But either way, anything is "do-able"
Post up that pic!
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
4 4in aeros (or port tube aka PVC) 18 inches long giving 36hz and 11.6 sqin per cube.
That'll work w/ the dimensions given I suppose. Haha. Good job ChevyBoy :drinks:
XS D6500 $245.65
sorry here is the dimensions of the outer box..
i had to build it in the car because its in a hatch with limited space.
i am going to modify this box for the ports.
the subs have to be facing up and the ports facing towards the cabin
hope this pic helps // ya i was having troubles trying to figure out how to post a pic on this forum =(
thx .. i made the ports today.. i need to learn how to tune ports. ( boxes ) hope this works
ok i was looking over this and i know i dont know how to tune a box.. but i was wondering if i add all 4 ports will my air space for the subs be way less now?? i know the sub needs a minimum of 1.75 - 3.25 max each .. so i need a minimum of 3.5 sqf or air space for 2 subs..
should i build the box bigger or stick with this? if i build the box bigger i have enough space for 1 more sqf
the new max size box i can fit would be height 15.5 width 36 depth 22.5 giving me a inner 5.87
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
