Posted (edited)
hey everyone i was thinking of buying 2 audioque 2.0 10s and i was wondering if this amp from amazon would run them good and loud the amp is a Kenwood Kac-9105D 1800-Watt Class D Mono Amplifier and pushs out 500 watts at 4 ohms and the rms of the subs is 250 each but im new to car audio but it seems like they are matched perfectly but i need other peoples help and is audio que an sq sub.
Edited by mustangbuzz64
For SQ look for some Image Dynamics IDQ's. You can do better than that Kenwood amp.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
well i dont have any subs or an amp but i think ill get the 2 10s but what amp should i get the aq or the kenwood amp cuz the kenwood is cheaper on amazon and puts out 500 at 4 ohms which is perfect for the 2 subs which are 250 each rms
Get the AQ 750 and the AQ subs they're great subs, sound good, and will pound really hard. Im running 2 AQ HDC3 12"s they get stupid loud but are not made to be Sound Quality sub theyre ment to get loud. Im sure you will be very pleased with that setup. My advise is to deffinatly build a box or have it made, dont buy a prefab box offline or at a shop. GL
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
ok so u think the aq amp but would i have to wire the subs so they are at 2 ohms then or the kenwood amp so they can still be at 4 ohms and still get 500 watts
Get either dual 4 or 1 ohm subs so you can wire it to 1 ohms at the amp. Get the AQ amp they are not "max" watts rated. The AQ is a wayyy better decision imo AQ subs and AQ amp :). You dont put the gain all the way up, set at at around half way and let those subs bang.(unless someone with an oscope lives near you, to set your gains). GL
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 1 Anonymous (See full list)
