building a box need help
What alot of people do is use bolts to attach the wires through the box. As for the port, like super said, its an 'L' port. Which basically means your port is so long it has to make a 90 degree bend before it hits the back wall. It needs to be the same distance as width of the port from the bend to the back wall. Which means youll take the port in (this is the size boards you need to cut for the port) 21.75", then youll make a 90 degree bend on the port ad go in another 2.75".
Sorry...thats not height...the height of the port is 14.5 because your total height of the box is 16 and the port is inside the box sandwiched between the top and bottom of two .75" boards which is 1.5" total. Sorry about the port length there though...messed up. The 21.75 is the length of the port inside the box, not the height. BUT I messed up and got confused, your actual length cuts should be:
15.75" in, then 90 degree bend to a 8.75" piece.
  • Who's Online   1 Member, 0 Anonymous, 1267 Guests (See full list)
