He gives you the dimensions in his above post. You'll want the first port wall 15.75", then the second to be 8.75".
Posted (edited)
He may be asking how wide the port should be... His wording is confusing me though.
If that's the case, you will want it to be 2.75" wide.
Edited by Supercharged DCs
Ok so all the way to the back of the box but leave 2.75" inches of space from the back anf how far to the left should it go
He may be asking how wide the port should be... His wording is confusing me though.If that's the case, you will want it to be 2.75" wide.
No, you answered him right, but he is over-thinking it on the bold part I fixed. He doesnt have to worry about that as long as he uses the cut sheets as I already put that into the dimensions. 15.75", then the second is 8.75". If they are put together like an 'L', then the space is already fixed. The second piece (8.75") should be on the inside face of the first port piece. (15.75") (this is probably just going to confuse him more...) LOL
Posted (edited)
Nvm
Ok, I was half drunk. So this will make a tad more sense...I decided to do a sketchup for you...then I noticed I made a totally :noob: mistake and didnt make your baffle big enough. You'll be able to see the port better too. Heres some new pics for you:
