mustangbuzz64 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Ok so all the way to the back of the box but leave 1.5 inchs of space from the back anf how far to the left should it go Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted August 25, 2011 Report Share Posted August 25, 2011 He gives you the dimensions in his above post. You'll want the first port wall 15.75", then the second to be 8.75". Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
tonedeaf Posted August 25, 2011 Report Share Posted August 25, 2011 What super said...the 1.5 is just what was taken away from the dimensions because thats the thickness of the wood. Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted August 25, 2011 Report Share Posted August 25, 2011 (edited) He may be asking how wide the port should be... His wording is confusing me though. If that's the case, you will want it to be 2.75" wide. Edited August 25, 2011 by Supercharged DCs Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
mustangbuzz64 Posted August 25, 2011 Author Report Share Posted August 25, 2011 So there will only be .25 inch from the back of the box to the pieace of wood before it bends in to the 8.75 inch pieace Quote Link to comment Share on other sites More sharing options...
tonedeaf Posted August 25, 2011 Report Share Posted August 25, 2011 Ok so all the way to the back of the box but leave 2.75" inches of space from the back anf how far to the left should it go He may be asking how wide the port should be... His wording is confusing me though.If that's the case, you will want it to be 2.75" wide. No, you answered him right, but he is over-thinking it on the bold part I fixed. He doesnt have to worry about that as long as he uses the cut sheets as I already put that into the dimensions. 15.75", then the second is 8.75". If they are put together like an 'L', then the space is already fixed. The second piece (8.75") should be on the inside face of the first port piece. (15.75") (this is probably just going to confuse him more...) LOL Quote Link to comment Share on other sites More sharing options...
mustangbuzz64 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Well thanks for the help guys I really appricate it and so last thing I promise the 15.75 sheet will run parrell with the 25 inch sheet and thanks again im justed confused on the port Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted August 25, 2011 Report Share Posted August 25, 2011 (edited) Nvm Edited August 25, 2011 by Supercharged DCs Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
tonedeaf Posted August 25, 2011 Report Share Posted August 25, 2011 Ok, I was half drunk. So this will make a tad more sense...I decided to do a sketchup for you...then I noticed I made a totally mistake and didnt make your baffle big enough. You'll be able to see the port better too. Heres some new pics for you: Quote Link to comment Share on other sites More sharing options...
tonedeaf Posted August 25, 2011 Report Share Posted August 25, 2011 Just a warning though, make sure you send these things clean power or you will blow them. As you will with any sub. Quote Link to comment Share on other sites More sharing options...
